BMW Wheel offsets-NLC
vet111s
Post by vet111s » Tue Dec 04, 2012 1:09 pm
Looking at sanjoy's bmw wheels in the classifieds but getting tied in knots about offsets etc.
Looking at them for my brother-in-law's e82 120d with m sport body etc. but cannot find the info I need for whether these wheels will fit re offsets.
The wheels in question came off sanjoy's 2007 320d
Ali
flyingscot68
Re: BMW Wheel offsets-NLC
Post by flyingscot68 » Tue Dec 04, 2012 1:22 pm
Have you tried looking on Mytyres? They usually give all that info.
philthy
Post by philthy » Tue Dec 04, 2012 1:50 pm
stadard offset is et47 for 7.5" and 8" wheels, what are sanjoys?
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
vet111s
Post by vet111s » Tue Dec 04, 2012 3:29 pm
They seem to be marked IS34 and IS37. Looks like too much of a difference?
Stevoraith
Post by Stevoraith » Tue Dec 04, 2012 8:04 pm
Sanjoys wheels are e46 style (but obviously replicas since they are 17s).
E46 3-series and e87 1-series are the same offset(ish) so anything from an e46 will fit.
The confusing thing is that Sanjoy had an e90 which use lower offsets.
If his wheels were e46 fitment they would have fitted his car but look a bit daft as they would sit quite far in the arch. They would also fit the 1er.
If his we're the proper offset for his car, they won't fit the 1er.
VX220 2.2 - Gone
kpb
Post by kpb » Tue Dec 04, 2012 8:59 pm
All ET/OFFSET is still dependent on tyre and wheel size so bear this in mind if you are trying to fit wheels from one model to a different model, also if the car is lowered then you may have issues with rubbing/non fitment due to fouling.
The higher the ET number the more the wheel will sit inside the wheel arch
1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45
3 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-20
3 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-35
3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30
3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47
3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27,
3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45
3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37
5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25
5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20
5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32
5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20
6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20
7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26
7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25
7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 15-25
8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53
X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.
Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread.
Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40
Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52
Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Taken from the site I used to size my 16" winter wheels to replace the 18" msport ones and no issues but the do sit well inside the arch as stevoraith says
Kinnon
a4drk
Post by a4drk » Fri Dec 07, 2012 12:52 am
I think Sanjoy has posted up the wrong photo.
He had a set of 17's on his 3 series estate - but it was a 6 spoke. - These had the winter tyres on them
I sold him a set of MV2's (as in the classified advert) which came off my Z4 Coupe.
He used these with the runflats as his summer tyre
If you look closey & screw your eyes up - around about the 9 /10 oclock postion - you can see the tyre size. 18
and at the 1 oclock position you can clearly see the letters "RFT"
I might be wrong......... only sanjoy can confirm.
David
S2 Exige
Post by Sanjøy » Fri Dec 07, 2012 9:25 am
I can confirm I have sleep deprivation and the ad was wrong.
