Portable Hard Drives (NLC)
Post by rossybee » Mon May 16, 2011 2:38 pm
Looking to buy one of these, quite commonplace offshore so plenty of scope for getting heaps of movies & full tv prog series :wink:
Also wanting to use for storing heaps of iTunes cr@p thus feeing up space on PC & laptops in the house.
Now, a bit of hunting on ebuyer & amazon shows possibly 1TB to be decent when it comes to capacity/vfm ratio (tight dundonian faction :mrgreen: )
And had kind of plumped for one on ebuyer around the £70 mark but then noticed more expensive ones with the USB 3.0 connections, which apparently is much faster.
So - questions - is it worth the extra dosh for USB 3.0 over USB 2.0?
Any other suggestions for one much appreciated :thumbsup
Needing to change my avatar
:blackeye
vxc
Re: Portable Hard Drives (NLC)
Post by vxc » Mon May 16, 2011 2:44 pm
for intial data transfer and as long as your lappy has usb 3.0 port
otherwise no point.
cstrachan
Post by cstrachan » Mon May 16, 2011 2:50 pm
Unless you are tansferring lots of data all the time then I would not bother. Lidl and Aldis often do very cheap external drives I have a few and they are all still up and running error free.
2003 Vauxhall VX220 2.2
2013 Astra BiTurbo
2015 Fiesta Ecoboost
r10crw
Post by r10crw » Mon May 16, 2011 2:53 pm
I just bought a 1Tb USB3 drive and whilst its quicker it does not meet the 10 times faster as quoted but this is due to the Harddrive itself, Im getting around 45Mb second transfer if thats any help.
So I would think at the moment the extra money is not justified. Also I payed 149.99 dollars for the Iomega 1Tb drive which is a small drive with no external supply.
Hairdresser at heart.
Blaque
Post by Blaque » Mon May 16, 2011 2:55 pm
Only if you have usb 3.0 on your laptop, or you can retro fit a usb 3.0 pci card in to your PC. You might be better with 2x 500GB drives like the WD passport. The 1TB ones are based on a 3.5" hard drive and require a seperate power supply, were as the smaller ones (2.5") take power from the usb connection on the laptop/pc.
r10crw
Post by r10crw » Mon May 16, 2011 4:22 pm
Blaque wrote:Only if you have usb 3.0 on your laptop, or you can retro fit a usb 3.0 pci card in to your PC. You might be better with 2x 500GB drives like the WD passport. The 1TB ones are based on a 3.5" hard drive and require a seperate power supply, were as the smaller ones (2.5") take power from the usb connection on the laptop/pc.
The one I have is a 1Tb USB3 and 2.5", it needs no external power supply but uses 2 USB ports for the power.
Skyenet
Post by Skyenet » Mon May 16, 2011 4:23 pm
Had many different external hard drives in the past and had problems with a few makes, however I do find the Iomega Prestige range dependable and good value.
http://go.iomega.com/en/products/extern ... rtner=4735
I have four (3 x 1TB & 1 x 1.5TB) and they are on 24/7 and no problems. Most bought at Tesco during promotions. All connected to Apple Macs.
2TB Iomega Prestige drive including free delivery for £80
http://dropship.weareelectricals.com/pr ... -2-TB.html
Dark
Post by Dark » Mon May 16, 2011 4:23 pm
If you want something portable look for a laptop type 2.5" HDD which is powered over USB.
Might be slightly slower but much less hassle with power adapters, etc.
USB3 not worth the effort unless your computer supports it.
I bought a 320GB Western Digital Elements from Tesco for about 40 pounds at Xmas.
You can get 500GB for that price now!
Cheers, Mark
Post by Corranga » Mon May 16, 2011 4:28 pm
Erica recently picked up a 1tb larger drive (ie with power adapter) for 45 quid. There are dome very decent deals out there on these things, but as others say, no point in usb 3 if you don't have it on your pc or indeed for a smaller usb powered 2.5 drive as I reckon it'll be slower anyways..
Ok, just checked and realised it was a scan today only deal:
http://www.scan.co.uk/todayonly/index.aspx
so it's not available now - made cheaper by me having lifetime free shipping from scan too :)
thinfourth
Post by thinfourth » Mon May 16, 2011 9:05 pm
rossybee wrote:Looking to buy one of these, quite commonplace offshore so plenty of scope for getting heaps of movies & full tv prog series :wink:
Its for porn isn't it
Post by Dominic » Tue May 17, 2011 2:38 pm
Great video Thinforth! :cheers
scottishselise
Post by scottishselise » Tue May 17, 2011 7:43 pm
250gb will do me nicely
Bargin:
http://www.scan.co.uk/products/250gb-fr ... ard-drive)
thanks
Post by rossybee » Wed May 18, 2011 10:11 am
Thanks for the suggestions chaps :thumbsup
Went for your recommendation Iain - 2tb Iomega Prestige - now only £66 :mrgreen:
Oh, and thinny - just found these for you :finger
:blackeye
