ScanGauge II Automotive Computer
Post by Sanjøy » Thu Jun 15, 2006 4:11 pm
Sure I have posted this on SED.
Woudl be useful for the S2s that have the plug for it. Pretty sure this is similar to the AA kit Gordon used to check for fault codes on Andys car at KH. Not sure what useful readouts you might get ...
As a general rule geeks like to have access to as much data and statistics as possible. We pretty much figure this applies to a geek's motor vehicle as well. So, to allow you to access extra information about your car we would like to introduce the ScanGauge II Automotive Computer. This gadget is easy to install and provides a set of digital gauges, a comprehensive trip computer, and an engine trouble code scan tool.
The digital gauges mode displays four different properties on the screen (for example, fuel economy, battery voltage, coolant temperature, and engine speed). The trip computer tracks your vehicle's maximum speed, average speed, driving time, driving distance, trip fuel economy and several other pieces of trip data. The engine trouble code scan tool lets you read standard engine trouble codes as well as clear the "check engine" light and other warning lamps.
The ScanGauge II is simple to use and install and mounts in, on or below the dash. It plugs into the diagnostic OBD-II connector found under the dash on 1996 and newer cars and light trucks. The functions are accessed viaa simple on-screen menu interface. There is an automatic delayed power-down after engine shutoff and automatic power-up when engine is started. User and vehicle settings are automatically saved.
Also has these features.
* Reads engine trouble codes and can reset the "check engine" light
* Trip computer that automatically tracks various elements of trip data
* Expanded digital gauges (fuel economy, battery voltage, coolant temp., etc.)
* No tools needed to install - plugs into the OBD-II diagnostic connector
* Simple menu driven operation
* User-settable backlight color and brightness - 126 possible color/brightness settings
* Batteries not required
* Dimensions: 4.8"W x 1.5"H x 1"D
* Connector cord length: 6 feet
* User adjustable contrast and update rate (slow, normal and fast)
* ScanGauge II compatibility list
* Big display - 50% larger than the original ScanGauge
* Cable detachable - can be connected on the back or side - RJ45 connection
* ScanGauge II to USB Interface available in August 2006. Allows data logging, field upgrades, data downloads and more
* One year manufaturer warranty
http://www.thinkgeek.com/gadgets/electronic/8426/
