Nitron Rebuild
offshorematt
Nitron Rebuild
Post by offshorematt » Fri Jun 02, 2006 4:29 pm
Has anyone on here ever had a set of Nitrons rebuilt? Was wondering approx cost and even a contact phone number if anyone's got one...
Cheers :D
Post by Gareth » Fri Jun 02, 2006 4:58 pm
01993 849449.
Think people deal with a guy called Guy.....
If I remember it aint cheap.
Apparentlly Nitrons need rebuilt after 18-24 months.
offshorematt
Post by offshorematt » Fri Jun 02, 2006 5:08 pm
Not cheap but very necessary. :( Two of them have started weeping after 20K miles on the hardest setting - this is a good time to go a little softer I think...
offshorematt
Post by offshorematt » Tue Jun 06, 2006 6:26 pm
For future reference, £50 a pop excluding VAT and delivery... Not as bad as I feared
Post by Sanjøy » Tue Jun 06, 2006 10:50 pm
Was there not a S2 set on fleabay going for 600 ?
Bob vanM
Post by Bob vanM » Wed Jun 07, 2006 7:47 pm
if you refurbish them, make sure they also look at the outside and supply new dustseals and alu rings ( or what are these mounting rings called ?)
they did not replace these even there was play in some (and I mentioned it)
but you will notice the difefference, the old oil inside tends to burn with trackuse and that effects the damping.
Bob vanM
offshorematt
Post by offshorematt » Thu Jun 29, 2006 4:11 pm
Refurb'd and delivered back to the office at only £383 (including 4 new piston rods). There's also a full set of the mounting spacer rings etc. Couldn't ask for better service.
What a relief. The comedy ride height Konis were getting depressing... :lol:
Post by Gareth » Thu Jun 29, 2006 4:32 pm
Excellent.
Geo next.
Bob vanM
Post by Bob vanM » Thu Jun 29, 2006 7:32 pm
good service,
glad they've learned :)
Post by simon » Thu Jun 29, 2006 9:58 pm
£30 less than my Protechs cost to buy new. :?
Post by tut » Thu Jun 29, 2006 10:17 pm
May be good service, but the shocks themselves are pretty unimpressive. And £383 for putting them right? The adjustment rings are pathetic, too small, and the rears are terrible to get at. They also seize up unless you constantly adjust them.
And 12 - 18 months for a rebuild is not on. Steve Butts modified S2 shocks are a better bet and around half the cost.
Not sure how the reputation of Nitrons has been built up so high, but they do not cut it for me.
Post by robin » Fri Jun 30, 2006 8:02 am
tut wrote: Not sure how the reputation of Nitrons has been built up so high, but they do not cut it for me.
Because they work well, are adjustable for both ride height and damping and fit the elise?
offshorematt
Post by offshorematt » Fri Jun 30, 2006 12:03 pm
:shock: Didn't realise they were so controversial!
To be fair I bought them second hand because they were available. I wouldn't have been able to justify the cost otherwise. I've had a great year driving on them, put in some serious mileage (+20K) and even with the refurb, I still haven't reached the 'as new' price. :D
Post by mckeann » Fri Jun 30, 2006 1:51 pm
i like them. to be honest, if your not on track, then the S2 bilsteins are more than good enough, but if you set the nitrons up properly, then they are a good damper.
A standard rebuild should cost 250 quid including VAT, but i needed 2 piston rods. obviously, after much abuse, these piston rods can bend, but so can the bilsteins.
Also, it lets you run stiffer springs, which is what i plan to do when i get a chance.
