Exige S
Exige S
Post by simon » Thu Feb 09, 2006 7:10 pm
The Lotus Exige S – breathtaking performance from the fastest accelerating Lotus ever to come off the production line
Summary
A small lightweight sportscar weighing just 935 kg (2057 lbs), powered by a 162.5 kW (218 hp, 220 PS) high revving supercharged engine, giving a zero to 100 km/h time of just 4.3 seconds (0 – 60 mph in 4.1 seconds). It comes straight off the production line and isn’t an “aftermarket specialâ€
Post by simon » Thu Feb 09, 2006 7:12 pm
Pic:
Lotus Exige S Specifications, Technical Details and Options
Vehicle Description Technical Specifications
Mid-mounted, transverse, 1796 cm3, 2ZZ-GE engine, Metal Matrix Composite (MMC) & aluminium lightweight and compact construction, 4 cylinders in line, water cooled. 11.5:1 Compression ratio, Double overhead camshafts exploiting a Variable Valve Timing & Lift with intelligence (VVTL-i) system, hydraulic tappets, 4 valves per cylinder, rocker arms with low friction followers. Lotus electronic throttle control system
Lotus developed supercharger installation including intake manifold, plenum and induction system, and air to air intercooler – (cooling air enters via the roof scoop)
Engine
Twin oil coolers (front mounted)
Engine management Lotus T4e engine control unit
Max Power 162.5 kW (218 hp, 221 PS) @ 7800 rpm
Max Torque 215 Nm (158.6 lb ft, 22 kgf m) @ 5500 rpm
Power to weight ratio 173.8kW/t (233.2hp/t, 236.4PS/t )
Specific power output 90.5 kW/_ (121.4 hp/_, 123 PS/_)
Three-way catalytic converterEmissions control .
Euro IV emissions compliant with full On-Board Diagnostics (OBD).
Transmission C64 Gearbox, aluminium lightweight construction, 6-speed, close ratio,constant mesh helical gears and open differential. (Limited Slip Differential option)
Fully independent sport suspension utilising unequal length wishbones, Bilstein mono-tube gas damper, Eibach coaxial coil spring at each corner and front anti-roll bar.
Suspension
Double-shear rear traction control arm brace
Chassis Lotus designed lightweight structure of epoxy bonded aluminium alloy extrusions with integral steel seat-belt support structure and lightweight steel rear subframe.
Steering Solidly mounted mechanical rack and pinion steering box with 2.8 turns lock-tolock.
Brakes Servo-assisted, track tuned 4-channel Anti-lock Braking System (ABS) with Lotus/AP-Racing twin-piston fixed aluminium alloy front brake calipers, Brembo single-piston sliding rear calipers and 282 mm diameter, 26 mm thick front and rear cast-iron ventilated & cross-drilled discs.
Wheels
Unique black lightweight cast wheels of eight x Y-spoke design (16â€
jamie
Post by jamie » Thu Feb 09, 2006 7:22 pm
Ha ha
Was in MMC a couple of weeks ago told Pauline 'they are bound to use that new yota with SC in the Exige.'
I am good! Will have to go and gloat :D
Post by Lazydonkey » Thu Feb 09, 2006 10:55 pm
£4k premium aint that bad really is it ?
.....i mean i know you are doing it for less Jamie, but its not as bad as when you look at 240R prices. :oops:
YvoTuk
Re: Exige S
Post by YvoTuk » Thu Feb 09, 2006 11:12 pm
simon wrote: It is certainly the quickest Lotus production car - so far!...
(121.4 hp / litre, 123 PS / litre)
935 kg, 2057 lbs)
(233.2 hp/tonne, 236.4 PS/tonne)
Pah....
>tapping on the rear wing of my Esprit S4s<
140PS / litre
1180 kg
271 hp/tonne
PAH!
:wave I guess Hethel burned the archives while closing the Esprit production line!
...now they said it was 300BHP where it actually was 320 :D But even with 300BHP the figures would look like:
136PS / litre
1180 kg
254 hp/tonne
:drink
jamie
Post by jamie » Thu Feb 09, 2006 11:33 pm
If I did not have my Exige I would go for the 240R now selling for 37K on PHs lot of goodies for your £s
Post by ed » Fri Feb 10, 2006 12:22 am
Those times seem a little optimistic!
4.1 0-60 Surely that aint right? :?
How does that compare to the 240R?
The_Rossatron
Post by The_Rossatron » Fri Feb 10, 2006 12:42 am
Sounds very nice to me - though I've never liked those wheels as much as the standard Exige ones!
jamie
Post by jamie » Fri Feb 10, 2006 8:16 am
Think they copy and pasted the 240R times which are optimistic as it is!
Post by Shug » Fri Feb 10, 2006 12:39 pm
The Lotus Exige S – more suitable performance from the Exige we should have launched in the first place
:roll:
Post by ed » Fri Feb 10, 2006 12:53 pm
so true! Dont want to know what its going to do to the secondhand exige market! :(
Post by Andy G » Fri Feb 10, 2006 1:03 pm
already asked MMC when the demo is going to be there. Looks like March time frame.
OTR cost £38.5k approx.
Its not meant to be announced for another 10 days or so :D
If the engine is technically the same as the GT3 version, surely someone will figure a way to liberate a few more ponies from it???
Post by Shug » Fri Feb 10, 2006 1:12 pm
Probably something really cheeky, like the Mini Cooper thing...
You know, the new Mini Cooper was exactly the same spec, engine wise, as the Mini One, the fly-by-wire throttle on the One was just calibrated so that it didn't open fully!!! :shock:
Still, easy power for those who know.
