Mobile Speed Camera
111Robin
Mobile Speed Camera
Post by 111Robin » Sat Nov 17, 2007 7:57 pm
I went past a mobile unit on the A90 today at somewhere between 75-79, definitely under 80. Anyone know if this is going to incurr a penalty ?. This speed is fine for going past the fixed cameras, are the mobile units different, ie. anyhting above the limit is a fine ?
Scottynic
Post by Scottynic » Sat Nov 17, 2007 8:22 pm
should be okay. pretty sure i have passed mobile ones about 80 and never heard anything.
TOO FAST TO LIVE TOO YOUNG TO DIE!!!
EliseR
Re: Mobile Speed Camera
Post by EliseR » Sat Nov 17, 2007 11:32 pm
111Robin wrote:I went past a mobile unit on the A90 today at somewhere between 75-79, definitely under 80. Anyone know if this is going to incurr a penalty ?. This speed is fine for going past the fixed cameras, are the mobile units different, ie. anyhting above the limit is a fine ?
My 111r speedo is not in sync with my tom tom sat nav tracked speed. The in car speedo always reports a higher value, I think 80mph = 73ish mph on the tom tom.
Not sure which is correct,
Gary.
Forde Freda Campervan! :D
http://www.LotusEliseR.com
Chas
Post by Chas » Sun Nov 18, 2007 12:25 am
yup, My sat nav shows about 6-7mph below what speed shows, i think you'll be ok. Your 80 would have been about 72-73
Chas
Titanium Exige S2 - 55 plate with Touring kit.
Skyenet
Post by Skyenet » Sun Nov 18, 2007 2:13 am
My old S2 speedo always exactly matched any GPS unit I used with it. Odd that newer Elises/Exiges don't' seem to be as accurate.
Every other vehicle I have owned (Car & Bikes) have all read between 5% to 10% over.
111Robin
Post by 111Robin » Sun Nov 18, 2007 12:15 pm
I was in the Golf but I guess the accuracy will be similar. I'll just keep my fingers crossed, I've only just got rid of 3 points from my licence, don't want any more so soon.
Post by j2 lot » Sun Nov 18, 2007 5:04 pm
Car speedo should always be accurate or up to 10% over read.
My cousin got pulled by traffic for doing 85 when 3 up, he and both passengers argued he was doing 70. Police then drove his car up to 85 following the patrol car - indicated 70 on speedo !! He got off with speeding ticket and had to get speedo in car replaced and have it inspected at MOT test centre.
He had had the car from new for a year and a half before this incident and had never got a ticket despite obviously always going much faster than he thought.
smee
Post by smee » Sun Nov 18, 2007 11:52 pm
Hmm, sorry to put a damper on this but I'd be concerned, in theory they can do you for 71, on A roads even dual carriageways they only let you off upto 75mph whereas it tends to be 80 on motorways. If you don't hear anything after a couple weeks you can probably relax, best of luck.
S1 Elise - LRG MMC
Exige 390 LRG
GR Yaris
Leighton T6.1
111Robin
Post by 111Robin » Mon Nov 19, 2007 1:01 pm
I don't see how they can penalise you for driving at a speed that doesn't trip the fixed cameras. I always set the cruise control at an indicated 77/78 as I know this is safe for the fixed cameras. How can they then claim a lower limit using another camera ?. Surely that's some form of deception ?.
Post by DDtB » Mon Nov 19, 2007 1:03 pm
111Robin wrote: I always set the cruise control at an indicated 77/78
Umm... so what you are saying is you intentionally break the law then..... :?
or is that kph you are setting your cruise control to.. :wink:
111Robin
Post by 111Robin » Mon Nov 19, 2007 1:13 pm
If the cameras don't flash then I can't be breaking the law can I. My speedo is obviously not 100% accurate, officer.
Post by simon » Mon Nov 19, 2007 1:37 pm
Skyenet wrote:My old S2 speedo always exactly matched any GPS unit I used with it. Odd that newer Elises/Exiges don't' seem to be as accurate.
[geek]
That's because yours had a Stack unit but the later cars have a Shurlock one that isn't as accurate
[/geek]
Post by Dominic » Mon Nov 19, 2007 1:46 pm
111Robin wrote:I was in the Golf but I guess the accuracy will be similar.
I reckon my golf (2006 Mk V) is over reading by approx 5-7% on the speedo.
RDH
Post by RDH » Mon Nov 19, 2007 1:58 pm
I hope my golf (2006 Mk V) is over reading by approx 25%-50% on the speedo.
steve_weegie
Post by steve_weegie » Mon Nov 19, 2007 2:20 pm
Dominic wrote: I reckon my golf (2006 Mk V) is over reading by approx 50-70% on the speedo.
Must be some VW trick to try and keep you legal dom ;)
