Cobra Alarm 8185
Edin430
Cobra Alarm 8185
Post by Edin430 » Wed Sep 26, 2007 10:19 pm
someone explain to me in simple "im a total idiot" english how this works?
2 buttons on the alarm fob which is for what, how many flashes, why two different sounding alarms etc etc.
many thanks :wink:
Post by BiggestNizzy » Wed Sep 26, 2007 11:11 pm
If i remember correctly 1 switches alarm on/off and 1 switches the interior zone off (if you leave the misses in it) it's 2 flashes on 1 flash off.
I await a correction :P
but in my defence it's been a while
Edin430
Post by Edin430 » Wed Sep 26, 2007 11:21 pm
that clears it up a bit!!
i switched it off (2flashes) interior light goes off - seconds later, alarm goes off!!
hit the wee button then the big one and its fine...
confused as to whats what 2bh....
Post by dezzy » Thu Sep 27, 2007 12:19 am
PM me your email address and the Cobra manual will wing it's way towards you ;) :thumbsup
cla5h
Post by cla5h » Thu Sep 27, 2007 2:05 pm
Cobra 8185 is the standard factory fitted immobiliser, and 8186 is an optional specd. upgraded alarm system.
Big button arms and unarms alarm/immobiliser (two flashes - armed, one flash - safe)
The little button has a dual function - press and hold when armed to sound a panic alarm, i.e. if someone's trying to stick something big up your bum, and you don't want them to.
It also turns off "cockpit sensing intrusion" if you press it once after arming the alarm, i.e. if you're leaving your roof off and you don't want the alarm going off whenever a cat jumps into the car.
Mine seems to be 8185 and a half, i.e. Lotus have it recorded as 8185, but my doors and access panels are alarmed. However, I don't have cockpit sensing (so don't need the little button.)
Post by Corranga » Thu Sep 27, 2007 7:42 pm
If its the same as mine...
Big button arms and disarms as above.
Little button does the panic and sensor thing.
To turn the sensor off, press the big button to arm the alarm.
I seem to have to wait until the lights have flashed then press the small button
You'll hear a *beep* that means you can leave the roof off and the alarm won't go off constantly.
I read the manual for mine ;)
Do these classify as CAT 1/2? I dodnt bother to tell my insurance about it, other than 'manufacturers standard fit'
Post by BiggestNizzy » Thu Sep 27, 2007 7:56 pm
Cat 1 I think I have a certificate somewhere :? was going to fax it over to elephant but they didnt care what it was as long as it had one
Edin430
Post by Edin430 » Thu Sep 27, 2007 11:54 pm
Thanks guys..
The Cobra 8185 is a That Cat 2 according to my insurer..
cla5h
Post by cla5h » Fri Sep 28, 2007 8:56 am
Yep, has to have the upgraded 8186 to get Cat1 - the car is listed in the insurers' database as only being cat 2 from factory.
So if anyone insists on cat 1 as part of the policy, they may ask for proof that it's been upgraded.
