Structural Engineer.....
Post by DDtB » Thu Sep 13, 2007 1:48 pm
I may be in need of one shortly..... regarding mounting 500kgs of plasma screens on a wall ...... anyone here with the ability to possibly help??
:D
Post by kenny » Thu Sep 13, 2007 1:51 pm
Nope
Post by DDtB » Thu Sep 13, 2007 1:53 pm
kenny wrote:Nope
Are you sure..... :?: There's a pint in it... :wink:
Post by woody » Thu Sep 13, 2007 1:53 pm
Rawl plugs :thumbsup
Post by kenny » Thu Sep 13, 2007 2:00 pm
woody wrote:Rawl plugs :thumbsup
For 500kgs? :lol:
See what i can do Dave, just out of curiosity where did you get a plasma screen that weighs half a ton?
offshorematt
Post by offshorematt » Thu Sep 13, 2007 2:02 pm
For 500kgs? :lol:
You want to get some No More Nails on that :thumbsup
Post by BiggestNizzy » Thu Sep 13, 2007 2:02 pm
Rawl Bolts :thumbsup
as long as it's mounted onto something solid (not plasterboard! ) I am guessing (and as a result will not be held responcible) the weight is almost entirely verticle so if you can't pull the bracket off it should be fine after all it's easy to hold a weight close to your body but hard to hold it at arms length, if you get my analogy
Post by Dominic » Thu Sep 13, 2007 2:03 pm
Blue tac :thumbsup
Post by mac » Thu Sep 13, 2007 2:04 pm
Yeah - but it's shear strenght you need to worry about.
That said your average 6" nail can carry about 1/2 ton of weight!
ikarl
Post by ikarl » Thu Sep 13, 2007 2:04 pm
500kgs??? :shock: :shock:
i don't think the iMax weighs that much :lol:
VX220 s/c
330xd estate
Post by DDtB » Thu Sep 13, 2007 2:05 pm
Don't know the construction of the wall.... looks like plaster... but thats why we need a structural engineer dude.....
it's for 2 walls... 16 plasmas on each wall in a 4x4 grid.... about 500kgs for each grid....
8)
Post by BiggestNizzy » Thu Sep 13, 2007 2:05 pm
DDtB wrote:Don't know the construction of the wall.... looks like plaster... but thats why we need a structural engineer dude.....
8)
metal frame ?
Post by DDtB » Thu Sep 13, 2007 2:07 pm
16 wall mount brackets, each one adjustable as the wall probably isnt completely flat.... bloody builders... :roll:
Post by kenny » Thu Sep 13, 2007 2:27 pm
Its not the shear strength of the plug/screws/bolts that is the problem but the shear strength of what you are fixing into.
Plasterboard wont work Dave :wink:
You will have to remove the plasterboard, add and position plenty of new timber studs (assuming its a timber stud wall and not brick) full height in the positions you need to put your anchors/brackets and reboard it. I wouldn't risk fixing through the board to where the studs appear to be.
max1966
Post by max1966 » Thu Sep 13, 2007 2:41 pm
Hit the wall firmly, you'll be able to tell what it is made of and report back!!
Chances are, even a stud partition well fixed at the headd and properly constructed will do the job.
Sheathing in ply will help spread the load and allow for additional fixings.
If its brick just use decent rawl plugs and make sure all the screws are nipped up nice and tight.
