First 50 miles
PhilA
Post by PhilA » Fri Mar 02, 2007 12:09 pm
i love hearing people being excited about their new lotus :D
Phil
Ford Focus Sport
thinfourth
Post by thinfourth » Fri Mar 02, 2007 12:29 pm
Lawrence wrote:Eh! No!
perhaps though we can persuade Myles to fit his bullet cam in the autotester this Sunday :)
mines already fitted :)
Post by Dominic » Fri Mar 02, 2007 12:36 pm
campbell wrote: Lawrence...your challenge is to mount the video cam in the pax corner of the windscreen and film yourself doing a Top Gear stylee road test review...you get to choose which of the May, Hammond or Jezza characters you would like to play...or you can just be yourself of course!
A 3 minute "short" posted up on Youtube is acceptable...
Up for it?!
Campbell
Lawrence going for the 'Stig style' commentry then? :wink:
greyrigg
Post by greyrigg » Fri Mar 02, 2007 12:44 pm
Glad all the deliberations were worth while.
I feel a wee run up the 'tub coming on. :D
Malcolm
Post by campbell » Fri Mar 02, 2007 1:16 pm
Up for it?!
Campbell
Eh! No!
OK can I do it instead then.
Post by tut » Fri Mar 02, 2007 9:09 pm
"I hear what your saying Mr Metro driver but after buying an Elise in 1996 I needed a change, this one is quieter, faster, comfier, and nearly the same colour."
Know what you mean Lawrence, did not need a change, just needed a twin to drive whilst mine was off the road, so got the closest that I could, one month younger, slightly different colour, and just need to remember to get in via the other door.
Lawrence
Post by Lawrence » Fri Mar 02, 2007 11:40 pm
Another 100 miles brings me over the 200
I had to refuel on the way back tonight, There are 2 little fuel pump symbols in the stackkkk, a yellow one and a black one, so when the little black fuel pump symbol on the right turned yellow to match its twin I thought I'd reset the trip and check the reserve mileage. 5 litres I remembered, so 30 miles should be a good estimate. We were near Haddington and the Granada at Musselburgh is only 15 miles further so easy peasy lemon squeezy :)
I always like to see how much fuel I can get in any tank, so a brisk run down the A1 was needed to burn up what's left. Some cones on the slip road at the bypass made me wonder for a second, and then as I tried to enter the services I saw the road was closed, with a diversion back up to Wallyford and through Musselburgh :roll: No thanks, I'll head on to Lothianburn Esso. Just back on the bypass and I now notice the last of my display fuel blocks have disappeared and I've 7 miles to go, down go the revs and constant throttle is the order of the day, no more squirts up the hill :) Is it miss firing? It's definitely pouring with rain, will we make it?. It was quite a long 7 miles, listening to every little noise, getting ready ready to coast as far as possible, scary stuff indeed. Worse still everyone I'd passed was repassing me :(
Well I filled the tank as much as I could, £30 of 95 ron and 34.94 litres
The tank only holds around 36 :shock:
I doubt I'd have reached the end of the bypass.......
Post by Mr Momo » Sat Mar 03, 2007 12:10 am
:oops:
close
bandit country.....
Post by robin » Sat Mar 03, 2007 12:17 am
:-) Close one ...
That's much the same as EGOR. You brim the beggar and you're lucky if you make 10 miles before it flips from full to 34L.
I spent some time messing with refuelling at different points to see how well calibrated the gauge is - answer, quite good! I have also cross-checked that against my fuel consumption (which is currently about 8 miles per litre = ~36mpg) so I can convert from odometer to expected fuel remaining and I get a good correlation.
So what these cars need is a bigger filler neck like the S1 has - that holds about 5L!
It's a real hassle for the S/C cars that can do as little as 4 miles per litre when hooned on the road - total range ~140 miles!!
For FF6 I was thinking about fitting some sort of extended fuel bladder, but there isn't much you can do that also remains safe - I don't fancy being caught in an elise covered in fuel and on fire ...
Post by Mr Momo » Sat Mar 03, 2007 12:21 am
If you've just been watching the Best of Chewin the Fat - you don't really want to be thinking about bladders and cars.....
Post by alicrozier » Sat Mar 03, 2007 8:32 am
Best I had in the Exige was 43.58L
It was reading 1/4 full and I was after considering another lap at the ring.
Pulled into the carpark and restarted and it read zero... :shock:
...coasted back to the petrol station.
Post by ExigeKen » Sat Mar 03, 2007 9:31 am
Hi Ali,
How are you getting on in Nigeria?
Have you ever been to Equatorial Guinea as I will probably be there in April installing a satellite network?
Ken.
Post by campbell » Sat Mar 03, 2007 10:44 am
Never mind the fuel test reports, what about some pics?
Post by alicrozier » Sat Mar 03, 2007 1:03 pm
ExigeKen wrote:Hi Ali,
Ken.
Sorry Off Topic:
Hi Ken,
I'm actually back in Aberdeen just now (since last Sat waiting on residency visa), moving down fully on Wed. with Nicola, cats etc. :shock:
Not been to Eq. Guinea, furthest was a couple of days in Port Harcourt...
Ali
Lawrence
Post by Lawrence » Sat Mar 03, 2007 1:46 pm
250 miles :)
