Drive by wire?
Its a bloody Elise for gods sake. S1's have drive by nothing, cept of course they drive by everything..........
Just thought I would give this thread a bounce. So, what results did you get Dan? I feel winter upgrade fever coming onroadboy wrote:I fitted some to a customer's S2 Exige and it makes a massive difference to the mid-range. The first cam is more aggressive so there is more torque available further down the rev range. This effectivley creates a power band between 3500 and 8000 insted of 6200 and 8000.
Its going on the rollers tomorrow to check the fuelling just to make sure the ECU can cope but no signs of it running lean yet.
The idle is a little lumpy but no signs of it stalling. This is to be expected from any engine running 285 duration cams on a plenum setup. I actually quite like the lumpy idle. Its what an Exige should be like.![]()
I'll post the results of the dyno run tomorrow. Not really interested in headline figures as they are pretty meaningless, just the torque curve and the AFR.
Dan@JPS
Think I'll be going for the reflash - just trying to find out if this will be available from dealers or whether the ecu has to go to Lotus Sport or Plansed wrote:nicked from exiges.com
£395 for a reflash and £795 for the new ecu and its supposed to be fantastic.....must resist........
