Raspberry Pi ...
Re: Raspberry Pi ...
Post by campbell » Sun Mar 08, 2015 12:29 pm
I just junked a 10 yr old Dell in perfectly serviceable condition which you could've had gratis, Nizz :-(
Post by BiggestNizzy » Sun Mar 08, 2015 1:28 pm
The original plan was to run a win xp machine with wamp for the web server and a copy of exel running in the background to generate the html. I thought the raspberry pi would have been easy, and It meant I could power it from the usb ports on the monitor. It also meant I could use it as an excuse to brush up on my php.
Post by campbell » Sun Mar 08, 2015 2:34 pm
The old Dell was XP :-(
Post by robin » Mon Mar 09, 2015 12:01 am
I should point out that my original post on this thread asking for R.Pi was meant to be tongue in cheek. Thanks to all those offering me their spare kit!
Post by BiggestNizzy » Mon Mar 09, 2015 10:38 am
raspberrypi wrote: pi@raspberrypi ~ $ ping 192.168.##.#
PING 192.168.16.3 (192.168.##.#) 56(84) bytes of data.
64 bytes from 192.168.##.#: icmp_req=1 ttl=128 time=13.9 ms
64 bytes from 192.168.##.#: icmp_req=2 ttl=128 time=71.5 ms
64 bytes from 192.168.##.#: icmp_req=3 ttl=128 time=26.2 ms
^C
--- 192.168.##.# ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 13.974/37.235/71.521/24.753 ms
pi@raspberrypi ~ $ telnet 192.168.##.# 1433
Trying 192.168.##.#...
telnet: Unable to connect to remote host: Connection timed out
graeme
Post by graeme » Mon Mar 09, 2015 11:19 am
Is your raspberry pi in the same subnet as your SQL server? Can you post the output of "ifconfig" from the pi?
Other possible issues:
1) Your SQL server is on a non-standard port (something other than 1433). Ask IT to confirm.
2) Your SQL server is restricted to only accept connections from certain IPs. Ask IT to confirm.
3) There's an over-zealous firewall in the way (more likely if they're not in the same subnet, hence the question above). Ask IT to confirm.
211
958
Post by BiggestNizzy » Mon Mar 09, 2015 1:07 pm
graeme wrote:Is your raspberry pi in the same subnet as your SQL server? Can you post the output of "ifconfig" from the pi?
Unknown - have asked Emax as they set it up.
Nope
no firewall.
raspberrypi wrote: pi@raspberrypi ~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:f0:7a:2b
inet addr:192.168.###.5 Bcast:192.168.###.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1490712 errors:0 dropped:5381 overruns:0 frame:0
TX packets:179494 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:90376623 (86.1 MiB) TX bytes:15217014 (14.5 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:708 errors:0 dropped:0 overruns:0 frame:0
TX packets:708 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:36924 (36.0 KiB) TX bytes:36924 (36.0 KiB)
WinPC wrote: C:\Users\gnisbet>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : PC-280612-W7
Primary Dns Suffix . . . . . . . : ####.local
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : ####.local
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : ####.local
Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connecti
on
Physical Address. . . . . . . . . : 5C-F9-DD-74-FF-67
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::e42f:b0cb:1974:d62%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.###.154(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 09 March 2015 07:54:38
Lease Expires . . . . . . . . . . : 10 March 2015 07:54:39
Default Gateway . . . . . . . . . : 192.168.###.1
DHCP Server . . . . . . . . . . . : 192.168.###.4
DNS Servers . . . . . . . . . . . : 192.168.###.4
192.168.###.16
8.8.8.8
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.####.local:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
graeme
Post by graeme » Mon Mar 09, 2015 1:19 pm
Stop hashing stuff out! Makes it harder. :) It's all non-routable so there's no security risk to telling us how your internal network looks. If anyone gets that far they can figure it out for themselves in seconds anyway. My home web server is 10.5.0.202. See, not scared. :)
So, the SQL server is 192.168.16.3
The Pi is 192.168.SOMETHING.5
What's this WinPC? That's not the SQL server, so how does that fit in?
What's the full Pi address WITHOUT HASHES! :D
211
958
Post by BiggestNizzy » Mon Mar 09, 2015 1:54 pm
graeme wrote:Stop hashing stuff out! Makes it harder. :) It's all non-routable so there's no security risk to telling us how your internal network looks. If anyone gets that far they can figure it out for themselves in seconds anyway. My home web server is 10.5.0.202. See, not scared. :)
I'm paranoid :D
the pi is 192.168.16.5
graeme
Post by graeme » Mon Mar 09, 2015 3:15 pm
OK, so they're both on the same subnet (192.128.16.0/24). It could still be firewall restriction, but that makes it a bit less likely.
I think you still need to check with IT which port the SQL Server listens on to see if it has been changed, and whether any old PC can connect to it or if it has been restricted by IP address. Both those things are SQL Server configuration, so you'll need the help of the IT bods that maintain the server.
If they can't help, there are ways, but best to just ask first.
211
958
Post by robin » Tue Mar 10, 2015 8:44 am
You can verify the 1433 part by looking at the ODBC connection configuration on the windows PC that is able to access the SQL server. If you dig about here:
https://msdn.microsoft.com/en-us/library/ms188691.aspx
You should find one on your PC (assuming your PC is using ODBC to connect Access/Excel to the SQLServer).
Post by BiggestNizzy » Tue Mar 10, 2015 9:23 am
Running std ports
Microsoft SQL Native Client Version 09.00.5000
Data Source Name: myEMAX
Data Source Description:
Server: HYSPEC-APPS\SQL2008
Use Integrated Security: No
Database: Emax-Live
Language: (Default)
Data Encryption: No
Trust Server Certificate: No
Multiple Active Result Sets(MARS): No
Mirror Server:
Translate Character Data: Yes
Log Long Running Queries: No
Log Driver Statistics: No
Use Regional Settings: No
Use ANSI Quoted Identifiers: Yes
Use ANSI Null, Paddings and Warnings: Yes
All the ports-1433, 1434 and 2382 are open (from IT)
graeme
Post by graeme » Tue Mar 10, 2015 10:05 am
Not convinced, but ok, we'll move on.
Next step, what happens if you telnet to the other ports, 1434 and 2382.? Also, try 21, 80, 443 and 3389. A connection would be a good sign, but no connection isn't necessarily bad. Just a bit of shooting in the dark to see what happens.
Then on the pi, run (without the '#' that represents the pi user's bash prompt)
# sudo apt-get -y install tcpdump
Then run the following commands one at a time
# cd ~
(change to the pi user's home directory, so we have permissions to write a logfile to the current directory)
# sudo tcpdump -v host 192.168.16.3 > tcpdump.log &
(run tcpdump, logging all traffic to the sql server ip and redirect the output to a file called tcpdump.log, instead of just spewing it onto the screen. The '&' runs this in the background so we can do other things while it's logging).
# telnet 192.168.16.3 1433
(try the telnet again, so tcpdump can capture the traffic. Wait for it to connect or time out or whatever. Quit the telnet connection and get back to bash prompt)
# fg
(to bring the tcpdump process back to the foreground)
Ctrl-C
(to kill the tcpdump process and stop logging)
Then edit tcpdump.log (using nano or vi or your choice of editor) and send me the contents (or paste them up if it's not too long).
211
958
graeme
Post by graeme » Tue Mar 10, 2015 12:51 pm
Next test:
# sudo apt-get -y install nmap
# nmap -p0-10000 192.168.16.3
(this port-scans the sql server to see what ports are open)
Copy and paste the output here, or PM me with it.
211
958
Post by BiggestNizzy » Tue Mar 10, 2015 2:03 pm
tcpdump Log comes back with nothing
nmap comes
PORT STATE SERVICE
135/tcp open msrpc
139/tcp open netbios-ssn
445/tcp open microsoft-ds
3389/tcp open ms-wbt-server
5357/tcp open wsdapi
10000/tcp open snet-sensor-mgmt
