Edin430
by Edin430 » Mon Oct 08, 2007 6:09 pm
might get some stick for this but i loved my mini...
had the cooper s works with the aero kit on it (was my boy racer days when i had the big kit and lambo doors as well
eventually bought a zeemax kit for it which i loved as well - still got a couple of the teles i took out of it after i crashed if i could find them!!
and i like the roof but then again im a blue nose
CSK_423
by CSK_423 » Tue Oct 30, 2007 1:49 pm
LotusLee wrote:The previous owner had them fitted from new, they are apparently an expensive option and I've heard the bracketry is prone to rust so just aswell getting some from Halfrauds. Mini2.com is pretty good for DIY tips or there is also newminiscotland.co.uk.
I've been doing a bit of reading up on the spotlight fitting. The puker BMW install looks like a nightmare no wonder it's so expensive, I looked at alt. and you can pick up a pair of lamps and brackets incl. wiring for around £60. This ties in with a relay etc. in conjunction with your main beam opposed to wiring it to your ECU and master switch etc. as you do with the BMW version.
