Buying an S1 elise
Re: Buying an S1 elise
Post by GregR » Fri Jun 20, 2008 9:36 am
Thread's a bit unweildy to search, so apologies if this has been suggested before re. the misfire:-
Taken off the distrubutor and checked that the wee carbon brush hasn't perished/fallen off? Dried out the distributor, changed the HT leads?
Post by Shug » Fri Jun 20, 2008 9:36 am
GregR wrote:Thread's a bit unweildy to search, so apologies if this has been suggested before re. the misfire:-
VVC - no dizzy.
s29ttc
Post by s29ttc » Fri Jun 20, 2008 9:46 am
YEah we presume the coilpack (or double coilpack) has gone, taking a trip up to Ali today get it sorted because I am sick of it haha. Changed the spark plugs, sized them made sure they where all right. Cleans all HT leads and it still misfiring so its either the leads or coilpack. Just going to leave it to Ali to sort then thats it done sick of mucking about with it I just want it fixed thats that.
1999 S1 Elise 111S - Fun Spec
Post by Shug » Fri Jun 20, 2008 9:53 am
Cool - guaranteed in a situation like that, it's always the last thing you change.
Paolo
Post by Paolo » Fri Jun 20, 2008 9:56 am
I take it the guy who sold it to you didn't mention the mis-fire issue?
s29ttc
Post by s29ttc » Fri Jun 20, 2008 10:17 am
There was no misfire issue when I bought it. I drove it 300miles up the road no problems and the next day a couple of hundred. I have just been very unlucky with it I think.
Post by Lazydonkey » Fri Jun 20, 2008 10:22 am
Or the seller was crossing his fingers as you drove away,and only uncrossed them when you got home :D
here's hoping is an easy / cheap fix :thumbsup
s29ttc
Post by s29ttc » Fri Jun 20, 2008 10:39 am
How could you mask it though? :? It didnt misfire once for 500 miles its just came :roll:
Post by Shug » Fri Jun 20, 2008 11:08 am
Probably just unlucky mate - it'll be having a strop 'cos it got sold :wink:
s29ttc
Post by s29ttc » Fri Jun 20, 2008 11:14 am
I would say so too no idea how he could have masked it the guy seemed very genuine. JUst a minor hicup sort it today hopefully :thumbsup
Post by mwmackenzie » Fri Jun 20, 2008 11:15 am
Could be a lambda issue!! worth checking out if you can borrow a sensor off someone else??? If the sensor is faulty and says the car is getting too much fuel when running normally it will cut the fuel back causing a missfire.. :?
Best of luck
Mark
Post by Shug » Fri Jun 20, 2008 11:19 am
Mark, with a VVC - I'd be 95% sure it's more HT related. I have one and it's the only temprament the engine has ever shown. The K's are less reliant on the Lambda than your turbo lump anyway - only ever used for emissions on cruise.
Post by mwmackenzie » Fri Jun 20, 2008 11:25 am
Saaweeet..... I retract the lambda comment.. Though I was basing it on my experience with a Grand Cherokee I used to have which developed a misfire and loss of power, greedy bloody car that was!!
Good Luck, Ali will fix it in a jiffy though!
Mark :thumbsup
Baggy
Post by Baggy » Fri Jun 20, 2008 3:43 pm
If you are changing the HT leads do yourself a favour and take a dremel to cut out an access hatch in the boot bulkhead and use that to help you get in about.
You will need it anyway if you ever want to change the thermostat without removing the inlet manifold.
Remove the boot liner/carpet and there is a little recessed rectangle about 3" x 12" right behind the two coil packs.
Baggy
Silver S1 111s
The Deen
s29ttc
Post by s29ttc » Fri Jun 20, 2008 5:56 pm
Yeah its into Ali now anyways get it back Monday or Tuesday hopefully. :D
