- Meat
by Scotty C » Thu Aug 23, 2007 10:31 am
mckeann wrote:S2 is better at high speeds. Less lift, so more stable.
Its the extra weight.
340 is very unstable above 150.
Stu160
by Stu160 » Thu Aug 23, 2007 10:35 am
mckeann wrote:my stack stops at 8000rpm, which is 160mph. limiter is at 8500 which is 170 but i've neveer got that far. yet.
Only managed 8450 rpm Neil
Stu
s333fee
by s333fee » Thu Aug 23, 2007 12:10 pm
what is the safe limit to take your engine to?
have, as far as I standard k series, no mods only un-usually go to 5.5K
by Rich H » Thu Aug 23, 2007 12:12 pm
Rev limiter is ther to protect the engine, just try not to buzz it with downshifts and it'll last ok.
s333fee
by s333fee » Thu Aug 23, 2007 12:27 pm
thanks,
was reading the pdf of the manual i got from someone here and noticed it was limited to 7K, hence was wondering why others were getting over this. The owner worries she will blow it up above 5.5K will let her know safe for 6K
by Rich H » Thu Aug 23, 2007 12:38 pm
Stu has an aftermarket ECU and his engine isn't exactly standard...
Also the Toyota (With the 6 speed box) has a much higher rev limit (7.8k) It will make you jump when you hit the limiter, it cuts the fuel and makes a racket, very distressing if your not expecting it!
It will blow up eventually, its a K, but that depends on alot of things you can't check, prevent or predict (How much the guy on the assembly line had to drink at lunchtime for example)
PRRT is supposed to help but nothing is definate.
by kenny » Thu Aug 23, 2007 12:40 pm
ed wrote:Im certain s2 exiges dont do 156tuts......
Depends if you are going by the clock or actual speed. You wont get any higher than the stated maximum unless you change gear ratios but if the Exige is similar to my old CTR for speedo readings, 147 actual speed would probably read around 162-164mph.
and stop right there.
by ed » Thu Aug 23, 2007 12:42 pm
Even if its on the clock. I sat at 150 for 2-3 minutes and it wouldnt go any faster!
ed on Thu Aug 23, 2007 12:42 pm, edited 1 time in total.
s333fee
by s333fee » Thu Aug 23, 2007 12:42 pm
only get above 4K or higher very occaisonally, on overtaking etc, not prolonged use.
thanks, will let S333FEE know.
S333FEE Support team
by kenny » Thu Aug 23, 2007 12:45 pm
ed wrote:Even if its on the clock. I sat at 150 for 2-3 minutes and it wouldnt go any faster!
Yours must have been gubbed then, when using the Road Angel GPS in the Exige and CTR both showed pretty much the same % over read from the speedo.
by ed » Thu Aug 23, 2007 12:47 pm
FYI 150 on the clock was 142 on the roadangel.
Lotus give 145 as the top speed but well all now about their reported stats!
by kenny » Thu Aug 23, 2007 12:47 pm
Thought it was 147?
by ed » Thu Aug 23, 2007 12:48 pm
I think 147 is the 111r....less drag!
by rossybee » Thu Aug 23, 2007 4:44 pm
Stu160 wrote:I have seen 8200 in 5th in my car,with K series lots of times.
With the s/c gearbox that was 137 tuts,on the track.
I am sure it is the same as 4th in a std box.
Stu
Early R500s (K series) did 9200RPM
2004 Bentley Conti GT
Now browsing the tech pages
Bada Bing!
by Bada Bing! » Thu Aug 23, 2007 4:54 pm
You ain't seen me right.
Bada Bing! on Thu Aug 23, 2007 5:13 pm, edited 1 time in total.
Gaz
"Ram it baw deep"
