A Big Thanks
- thinfourth
- thinfourth
And the engine seems amazingly smooth for a V8!
Phew!
Been working all day on it, and there's a lot to do.
Will eventually have to change all 6 shocks (yes, 6) because the shaft has rusted from not being driven
But before changing them will remove the rust with sandpaper and see when they start leaking.
Need air filters, and then to time the engine (anybody has one of those strobe timing guns they don't use anymore?). After it's been timed then I'll have to find the way to carburate it, it running kind of lean (my guess).
Fixed some vaccuum leaks, throttle play, travel, cleaned carburators, washed engine, made new brackets for the battery (the Exige battery now lives there) and generally noted a few things that need to be changed (almost always related to rubber, like hoses seals, etc)
There's a couple vent-like hoses in the carbs that I still have no idea what they do.
Ah, and need a new clutch master cyl, as the other one had no cap and it was full of water, mould and slime (and part of this is inside the clutch line)
I wonder how many bleeding nipples are going to break later
Anyway, Paul is off on his cruiser boat next Saturday, but other wise I would have thought the car would be ready to go out as soon as next Saturday!.
Let's see...
Phew!
Let's see...
- thinfourth
Re: A Big Thanks
A rather late update
But Shrek has a new home and he is now mine
Its my first V8
Already sorted a few jobs like fix the clutch pedal and had a crack at the overheating problem by chucking the thermostat in the bin
Now just got to find out how to stop it burping and farting back out the carbs, strange these carb things personally i don't believe in them
Its my first V8
Re: A Big Thanks
Pics please......for the n00bie!
- thinfourth
Re: A Big Thanks
You mean apart from the two on the first page of the threadmeatball wrote:Pics please......for the n00bie!
Re: A Big Thanks
I will look when I get home......this computer only shows me a grey square!
What is shrek?
What is shrek?
Re: A Big Thanks
It would be nice to have some photos after all the work you have done hopefully without the mould
