Microsoft Sharepoint and SQL
Re: Microsoft Sharepoint and SQL
Post by robin » Tue Oct 20, 2015 8:31 am
BiggestNizzy wrote:Got it
Code: Select all
ao.[Actual Run Time] + ao.[Actual Setup Time]+
cast(  datediff(minute,stl.[Start Time] ,convert(varchar(10),getdate(),108)) as decimal(18,5))/60  as [Run Time] ,
	ao.[Run Time]+ao.[Setup Time]-(ao.[Actual Run Time] + ao.[Actual Setup Time]+
	cast(  datediff(minute,Stl.[Start Time] ,convert(varchar(10),getdate(),108)) as decimal(18,5))/60)  as [Var]
That might work, but I really don't think you should need to be using substrings to extract time fields and then doing arithmetic on them - any sane system stores dates/times in some basic unit (seconds, milliseconds, whatever) and should be able to do arithmetic at that level. Anyway, I am assuming you're happy with the solution, so shall not agonise over it too long :-)
Post by BiggestNizzy » Thu Jun 30, 2016 2:29 pm
Guys your help was greatly appreciated last time and I was wondering if I could call on the collective wisdom of the group again :D
I have been playing with SQL again but I am stuck.
First off I made this up and it worked
Code: Select all
SELECT
	SFDC_Transactions.Operation,
	SUM
		(datediff
			(minute,
				(SFDC_Transactions.Start_Time+SFDC_Transactions.Start_Date),
				(SFDC_Transactions.End_Time+SFDC_Transactions.End_Date)
FROM
"Emax-Live".dbo.SFDC_Transactions SFDC_Transactions
WHERE
	(SFDC_Transactions.Work_Order='NP') AND
	(SFDC_Transactions.Live=0) AND
	(SFDC_Transactions.End_Date>=getdate()-7)
GROUP BY
(Dates and times are held seperatly and I need to join them together)
It produces a table like so
code - time (in mins)
10 - 500
20 - 500
30 - 500
40 - 500
I then wanted to relate the codes to something meaningfull and I had to jump through hoops (jump across some tables) to find this.
Code: Select all
SELECT
	WO_Op_List.'Op Description',
SUM
	datediff
			minute,
FROM
	"Emax-Live".dbo.SFDC_Transactions SFDC_Transactions,
	"Emax-Live".dbo.WO_Op_List WO_Op_List,
	"Emax-Live".dbo.WO_Operations WO_Operations,
	"Emax-Live".dbo.WORK_ORDERS WORK_ORDERS
WHERE
	SFDC_Transactions_List.Operation = WO_Operations.Op_No AND
	WO_Operations.WO_ID = WORK_ORDERS.WORK_ORDERS_ID AND
	WO_Op_List.WORK_ORDERS_ID = WORK_ORDERS.WORK_ORDERS_ID AND
		(SFDC_Transactions_List."Work Order"='np') AND
		(WORK_ORDERS.WO_No='136012') AND
		(SFDC_Transactions_List."End Date">=getdate()-7)
GROUP BY SFDC_Transactions.Operation
When I try to run It I initially get a syntax error before I get
The multi-part identifier "SFDC_transactions_list.operation" could not be bound.
The multi-part identifier "SFDC_transactions_list.Work Order" could not be bound.
The multi-part identifier "SFDC_transactions_list.End Date" could not be bound.
I expect it to be something stupid like a missing comma but I can't get it to work.
Any help would be greatly appreciated.
hendeg
Post by hendeg » Thu Jun 30, 2016 2:44 pm
You don't have a SFDC_Transactions_List table listed in your FROM section.
Should that be SFDC_Transactions?
Exige GT
Post by BiggestNizzy » Thu Jun 30, 2016 3:15 pm
hendeg wrote:You don't have a SFDC_Transactions_List table listed in your FROM section.
I am a nugget!
Code: Select all
SELECT
	WO_Op_List."Op Description",
SUM
	datediff
			minute,
FROM
	"Emax-Live".dbo.SFDC_Transactions_List SFDC_Transactions_List,
WHERE
GROUP BY WO_Op_List."Op Description"
now I have a new problem :D
arithmetic overflow error converting expression to data type int warning:null value is eliminated by an agrregate
hendeg
Post by hendeg » Thu Jun 30, 2016 4:02 pm
Not sure but as you're looking at transactions in the last 7 days would you have any that aren't complete and have NULL end date or time?
Exige GT
Post by BiggestNizzy » Thu Jun 30, 2016 5:09 pm
hendeg wrote:Not sure but as you're looking at transactions in the last 7 days would you have any that aren't complete and have NULL end date or time?
When I did the >=getdate()-7 on the end date I had hoped that it wouldn't pull anything that wasn't running. I have taken the SUM and Group BY out and I appear to be getting duplicate values (65k+ records) and that is bringing with it some mega numbers when you add them together.
hendeg
Post by hendeg » Thu Jun 30, 2016 9:36 pm
Try replacing getdate()-7 with dateadd(day, -7, getdate())
Exige GT
Post by Ferg » Sat Jul 02, 2016 10:28 am
Not sure if helpful in your specific context, but if your doing elapsed time comparisons from a DB then I always used to use 'epoch' as it's literally a date in a number of seconds. Then you do all your calculatuons in seconds and it makes life a lot easier. You can then convert epoch to date if you need a result in readable format. Just had a look and MSSQL supports epoch.
It's been a while since I was an SQL slinger but this approach was often the most powerful. Not been on front line for a few years though. ;-)
Post by BiggestNizzy » Sat Jul 02, 2016 12:25 pm
Cheers guys I managed to get it working but will take another look at using your suggestions. The database is a bit of a nightmare it's from an ERp system where it appears you have fudge built upon fudge, dates are not always stored as dates (sometimes as text) for example. I have tables that are identical but with a couple of extra columns that allow it to link in.
It would probably help if I could get my head around "JOIN" but I just end up using value = value
johncam
Post by johncam » Sun Jul 03, 2016 10:23 pm
BiggestNizzy wrote:The database is a bit of a nightmare it's from an ERp system
Its not EFACS by any chance is it?
John
JohnCam
Lotus Esprit Turbo SE
Mercedes Benz E63 AMG
Merlin Extralight
Merlin XLM
Post by BiggestNizzy » Sun Jul 03, 2016 10:26 pm
John
No it's emax. To be fair to them I haven't met anyone who likes the particular ERP system they use.
Post by BiggestNizzy » Wed Jul 13, 2016 9:48 pm
Hi guys got all that to work. But I am trying to get my head around joining tables rather than pulling everything in and then filtering it .
If I have 2 tables (table 1 and 2) and I want to join them together on fields with the same values but different names
Table1.opno
Table2.operation
FROM
Dbo.Table1 CROSS JOIN
Dbo.Table2
I am guessing just adding a join won't do as the column names are different but I am also having problems as one is an integer and the other a varchar field with data that's wrong (instead of numbers we have random txt) should I be using something like a RIGHT JOIN ?
edited to change JOIN to CROSS JOIN
hendeg
Post by hendeg » Thu Jul 14, 2016 9:36 am
If you want to join the tables and return only rows where the values of your join match then you'd user INNER JOIN.
SELECT *
FROM Table1 INNER JOIN
Table 2 ON Table1.opno = Table2.operation
However, because you have different data types I don't think you can use a join. You'll have to do;
SELECT *
FROM Table1, Table 2
WHERE Table1.opno = CAST(Table2.operation AS INT)
assuming Table2.operation is the varchar field and the values can be converted to INT.
Exige GT
Post by BiggestNizzy » Thu Jul 14, 2016 12:25 pm
Cheers I changed it to an INNER JOIN ON table1.op table2.operation It appears to cut out all the crap as the data in table2 should be concidered the gospel.
Post by BiggestNizzy » Tue Aug 23, 2016 5:51 pm
Been busying myself away with this and I have a reasonable idea of what I am doing with basic sql. As a result I have created a good few webpages that pull data for a database and display it on a TV using a raspberrypi booting straight to a webpage.
Problem I now have is I have lots of webpages that are usefull and some that are nice to have on the odd occasion.
I am using
<meta http-equiv="refresh" content="60;url=http://webpage/page2.aspx">
on page 1 and when it gets to page 5 it sends it back to page 1
However pages 1 & 3 contain inportant information. the rest are more like notices.
Does anyone know how to write a page that will
Load page 1
then load either page (2,4 or 5)
Load page 2
repeat
It would be great if it could be handled from a seperate XML file or something. I have tried googling but can't find anything similar.
I was going to try a kiosk example with win 10 iot core but my play raspberrypi got used.
Any help in pointing me in the right direction would be greatly appreciated.
