looking at s160
- Victor Meldrew
Craig, gimme a shout if you want a natter about options...
In a nutshell, your 135 is a ported standard head. Options for this, while keeping it in 1 piece, inlcude a cam swap a la Rich Humble. Should see you with a decent 150/160hp, probably keeping the MEMS. Do a few other things (like decent manifold and bigger TB) and you'll get useful power hike for not a huge amount of cash.
Further than that, I'd strongly advise looking beyond the standard head casting - going for either a VVC or PTP (VHPD) head, which has far superior valve sizes and port shapes.
Then you've got Emeralds & DTH Throttle Bodies & the like...
Also, don't discount finding a used VVC engine and dropping it in - now that I've found the pitfalls with doing one, there's a source of info on doing it.
You could quite easily get a useful 170/180 bhp for less than the cost of swapping - what way you go about this depends on the sort of power delivery you're after.
Although....shooomer wrote:Thinking out loud
IMHO the Sport 135 is probably one of the most desirable S1 Elises if left fairly standard.
I think you'd probably notice a bigger difference in performance upgrading Sport 135 than swapping to a Sport 160 however any money spent on mods is basically lost if you sell vehicle.
You could probably swap to Sport 160 for ~£2k.
The majority of the perceived speed gain is thanks to the standard CR box on the 135 - which is missing on the 160. Betcha the 160, with the peaky delivery and long box will actually feel slower....
- Victor Meldrew
So.... a moded 135 could be be a fair bit quicker than a 160....
Dont know enough about the PTP to say if the 135 Janspeed head is any better than their head.. cant be much in it though, a ported head is a ported head. After that if fall to the valve sizes and valve springs I would have thought.
And if you keep the bits when you convert, you can go back to std when you sell the car on, then sell the bits on here to get some money back.
From my conversation with someone in the know (Dan at JUDE) you "need" verniers and an emerald to unlock the real potential of a 160.
So if you take that into account, all you need to duplicate? a 160 starting from a 135 as a base is a set of cams.... ..or is my logic just a bit out?
P.S. I am planning a cam swap for next summer, but dont tell Lesley. I have to come out with the "the std ones are worn and need replacing, its a high stressed engine you know, these things happen..!!!!"
- Victor Meldrew
as above with a cam swap for me, shouldnt be much of a difference.NOOPS 160 wrote:Verniers and emerald according to Dan would transform the 160 ........John Reid wrote:So.... a moded 135 could be be a fair bit quicker than a 160....
P.S. I am planning a cam swap for next summer, but dont tell Lesley. I have to come out with the "the std ones are worn and need replacing, its a high stressed engine you know, these things happen..!!!!"135 pahhh.sorry John
it all comes down to how hard you pedal in the end...
- craigs135s
Ah, but apples and oranges. If you're talking the PTP 170 head, that's not a standard casting. The 135 & 160 start out as standard K castings then are ported out. The PTP 170 is a VHPD head, which is actually the same port shapes and valve sizes as the VVC - much better even as a bare casting than you could ever get from porting a standard head - the port shapes are miles better, straight out the mold.John Reid wrote:So.... a moded 135 could be be a fair bit quicker than a 160....
Re valve sizes, the biggest inlet valves I could get in my standard head inserts was 29.5mm - the VHPD and VVC inlet valves are 32mm as standard.
Shug wrote:Janspeed did the first 135 heads....mac wrote:Craig,
I think you'll find that PTP did the porting work for lotus on the S1 - 135 & 160 heads.
I've found them to be sound folk - drop them a line for their input
What they did the first 135 heads for the 135 or the did the first run of heads for the 135?
what about the 160 - did they do 160 of them, or the first run for the 160 or none at all?
- Victor Meldrew
I am 99% sure that the 135 heads are CNC machined, so provided you have a proper machine, the differences between sources are negligable. Of course you might still have a swiss cheese head, but that's nought to do with the 135 conversion.John Reid wrote:I am sure Janspeed did the first run, i.e. first 50 heads on the original batch of 50 SVA type approved 135's
They have a Janspeed exhaust manifold and back box as well I think.... well mine does....
