It's like an Aladdin's cave isn't it?r10crw wrote: ...and they do have some lovely engineering work going on there...
A different engine conversion
- offshorematt
Re: A different engine conversion
Engine from Malc at Yorkshire Engines (so it'll definitely be ok and you have some comeback) - supplied with the full loom ECU if you ask for it - may be cheaper and less hassle than a full bike, lateral car wet sump from one of many suppliers like Rilltech / Extreme Engines, bike ECU will probably be perfect unless you want to put a different ECU and spend loads getting it mapped as well as the OEM one . . . simples
. . . many, many hillclimb single seaters use this exact route so it's well understood, almost none use dry sumps, probably use an electric water pump given the length of the pipe run to the front of the car . . . good project, dunno why more people haven't tried it . . .
seems logical to me, i started having similar thoughts as well but they stemmed fro musing this as a powerplant.
http://www.ninja-h2.com/
S2 111s
campbell wrote:Superb project, Craig!
Build thread pls
If anyone can get around some of the engineering issues, Craig can.
You will need a reverse gear.
So, you will need a Quaife Transverse box.
This is what was in my old Westfield Megablade.....
Once, in an empty carpark, i was reversing quite fast & changed gear 3 times
think i got up to 40mph in reverse, then crapped my self.
David
David
S2 Exige
BMW 435d M Sport - 375bhp..... and stops now (big brakes!
Work Horse - Ford Transit - Full of crap spec....... 170bhp one
S2 Exige
Look forward to seeing this Mattoffshorematt wrote:It's like an Aladdin's cave isn't it?r10crw wrote: ...and they do have some lovely engineering work going on there...When you were in by, don't suppose you saw the blue 1972 fiat 500 getting the 1.6litre Subaru conversion? That's mine
They're bringing it back from the dead. Going to be a bit trigger's broom when they're finished but really starting to make some progress at last (it's been down there over a year) and should be in the paint shop this month. Nice folk to deal with, but crazy busy all the time.
Now browsing the tech pages
