Coffee machine (NLC)
pete
Vexatious Litigant
Re: Coffee machine (NLC)
Post by pete » Thu Oct 13, 2011 9:00 pm
Thanks for all that - the Gaggia one looks spot on.
(Look I don't know anything about coffee - as far as I am concerned you can't beat a good mug of tea. Nor should you try). We end up going to certain friends because they have a coffee maker. And certain cafes because their coffee is better. No-one cares that they can't make a good cup of tea and don't seem to even TRY. What's a latte? Does that Gaggia Latte Art do that? (I'm guessing from the name).
October and I have Christmas sorted.
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
AJT
Post by AJT » Thu Oct 13, 2011 10:15 pm
Tassimo does Tea and Hot Chocolate as well. :cheers
Alan
S2 111S
Post by BiggestNizzy » Thu Oct 13, 2011 10:18 pm
Does the coffee maker break the household gift rule ?
Post by Shug » Fri Oct 14, 2011 8:45 am
BiggestNizzy wrote:Does the coffee maker break the household gift rule ?
Didn't for me (Elaine bought me it) - as Elaine barely drinks the stuff and it's a gadget, innit. Okay, I'll make her hot chocolate occasionally with the milk frother, but that's about as much use as she gets out of it.
Post by tut » Fri Oct 14, 2011 9:03 am
There are two models of the Cubica, one is the Plus which has knobs instead of push buttons, we had one of the latter and had to replace a switch twice.
Post by Shug » Fri Oct 14, 2011 9:06 am
The plus might be a good shout, as the only issue I have with mine is the buttons. Never had one fail, but they feel a bit '80s Fiat, IYSWIM...
Is the plus physically smaller though? Not sure I'd want one smaller than the standard Cubika (would look like a toy IMO)
tuscan_thunder
Post by tuscan_thunder » Fri Oct 14, 2011 9:43 am
shooomer wrote:
tuscan_thunder wrote:
shooomer wrote:I have a new coffee project and can supply high-end beans
Tell me more, my need for caffeine and tar-like espressos knows no bounds.
(As an aside, this guy does great coffee: http://www.homegroundcoffee.co.uk/about-us )
I use a Krups machine for espresso and it's not bad but not in the same league as some of the proper jobbies.
I'll get you some samples :thumbsup
ta.
Mair throttle, less brake
Post by GregR » Fri Oct 14, 2011 9:54 am
Shug wrote:My Gaggia Cubika takes a solid kicking daily - at least 2 cups a day and I've had it nearly 2 years now without a missed beat. Buttons feel a bit gash, but can't argue with the quality of the output.
I've got the same machine, and all I would say about it is that you have to have it on for some time before the output is hot enough. Its not a case of turn on, fill, make lots of noise and piping hot black goodness. Its more a case of get up, fill, switch on for a warm-up, go for your morning Treble-S, come out, switch on.
Post by Shug » Fri Oct 14, 2011 10:01 am
True - I often switch it on and wander back to the PC to do some emails and come back an hour later with the thing threatening to take off :) But you're right, it's not an immediate switch on and go.
Post by GregR » Fri Oct 14, 2011 10:03 am
I should point out - I don't consider that a criticism - more a little bit of itallian Quirkiness :)
shooomer
Post by shooomer » Fri Oct 14, 2011 10:37 am
What grinders are you guys using? I've never made espresso at home
Paul
Brewed Faction
Post by jj » Fri Oct 14, 2011 10:46 am
GregR wrote:I should point out - I don't consider that a criticism - more a little bit of itallian Quirkiness :)
Both my Classics are the same, turn on and come back in a bit. In fact I just turned it on for the mornings blue milk frothed then triple espresso with 3 sugars mug full :lol:
The only issues I have are the water down here is different to Scotland, and if you use tap water they pretty much go solid inside within months with limescale. Have to use cheapo bottled water.
Post by woody » Fri Oct 14, 2011 10:49 am
shooomer wrote:What grinders are you guys using? I've never made espresso at home
Paul
Brewed Faction
Paul, still getting my regular supply from Tinderbox/Mathew Algie, and occasionally Artisan Roast.
I get Tinderbox to do me the finest grind on their Mazzer, take home and keep it in the freezer. 500g lasts a fortnight, so within their brew before spec. Cost/benefit on a decent grinder for the house Vs the above dosen't work out.
As far as the cubika goes, I think the plus is a Philips machine in disguise.... Had a button go on my cubika after 6 months (it's a very early model as well), was replaced under warranty with the newer spec buttons.
I'd go for the classis from the POV of future parts replacement. Group gaskets are different from all other gaggia's and a pain to get a hold of IME for the cubika, and the plastic/aluminium handle's have broken a few times; classics use brass IIRC. Classic is a higher wattage, so should heat up a bit quicker too. I'm feeling the need to buy one again...
Post by Sanjøy » Mon Oct 24, 2011 9:39 am
I use an Aeropress and hand grinder at home
Is it hard to use or can you use it effectively on top of a cup without the stainless holder.
shooomer
Post by shooomer » Mon Oct 24, 2011 10:57 am
Aeropress? Yep, straight on the cup top :thumbsup there's a couple of techniques that aren't in the instruction manual
