by woody » Thu May 25, 2006 10:33 am
Nope, but carrick engineering around the corner from us are 1st class. I've had then do a few sets of wheels, rocker covers etc... and they do a lot of jobs for my work.
TBH, SC black, baked on in the oven should last a good while though.
by Sanjøy » Thu May 25, 2006 10:36 am
Can get themo ver to you no problem, proble mis getting them out again as the nuts are spinning now. Must be info on selcock / bcbbs.
The nose cone black stuff suond the biz.
by Rich H » Thu May 25, 2006 10:43 am
Erm yes, those rear bolts are fun arn't they.
I had to chop mine off with a hacksaw but mind the clam! Mine are now SS.
Good luck!
by Sanjøy » Thu May 25, 2006 10:49 am
You get in to them from the boot I take it ? Hmm I think I have found my excuse to buy a dremmel.
by Rich H » Thu May 25, 2006 11:11 am
Nope I don't think you can, I cut mine off from the ourside.
by Sanjøy » Thu May 25, 2006 11:31 am
So you welded on new "legs" ?
by Rich H » Thu May 25, 2006 11:35 am
Nope, the bolts are at the top then pull out the top and tilt towards you. The legs at the bottom are held in little rubber grommets on mine.
by Sanjøy » Thu May 25, 2006 11:39 am
Coming back to me now, so there are teh plastic recepticles in the clam and then the plastic screws at the top ?
by Rich H » Thu May 25, 2006 12:04 pm
Mine were little wire legs at the bottom into grommets and mild steel bolts into rawl nuts at the top. Pig to shift as it was all rusted solid.
Derek
by Derek » Thu May 25, 2006 12:06 pm
In a similar vein, can anyone do powder coating, preferabley located in the East Coast/Central Belt? I could do with the rear undertray done in black.
Derek
by Sanjøy » Thu May 25, 2006 12:17 pm
I am back and forth to GLA from Edin in the Rav every other week ....
Derek
by Derek » Thu May 25, 2006 12:21 pm
I see a plan forming.
by Rich H » Thu May 25, 2006 12:25 pm
Powder coat vs thin ali undertray? Has it been done before?
I'm curious that the powder coat will be flexible enough. good idea though. Spinner black would probably be ok though.....
by mac » Thu May 25, 2006 5:21 pm
IainF just used to clean his undertray with alloy wheel cleaner and then spray it black with a can from Halfords IIRC
by Sanjøy » Thu May 25, 2006 5:26 pm
Am I missing something about cleaning the undertray or is it a S2 thing ?
