Barum Tyres
Re: Barum Tyres
Think I found them here:
Fronts
http://www.camskill.co.uk/products.php? ... 0s287p6363
Rears
http://www.camskill.co.uk/products.php? ... 0s302p6374
Might just order these up
Fronts
Rears
1999 S1 Elise 111S - Fun Spec
Re: Barum Tyres
Not quite the right ones. The fronts you have have there are the narrow 185s, but the rears are the wider 225s. You either need the 185F/205R factory sizes, or the 195/50/15F & 225/45/16R wider fit that most folk go for.s29ttc wrote:Think I found them here:
Fronts
Rears
HTH
1995 Volvo 940SE Estate
Re: Barum Tyres
Ahhhhhhhhh, see I took the sizes from the tyres on the car at present??
Its the 111s elise. I do believe the last owner increased the profile of the tyres a bit and it seemed fine so was going to stick with it.
What should I be buying then 195/50/15 for fronts and 225/45/16 for the rear. I take it the 195's will fit aswell as the 185's but the 195's are the better ones to go for?
This tyre game is too complex
Re: Barum Tyres
Re: Barum Tyres
That's correct Scott, 195 fronts, 225 rears.
Re: Barum Tyres
So order these ones?
Front
http://www.camskill.co.uk/products.php? ... s288p15058
Rear
http://www.camskill.co.uk/products.php? ... 0s302p4974
Front
Rear
Re: Barum Tyres
I think everyone is pointing you here:Tom wrote:Not quite the right ones. The fronts you have have there are the narrow 185s, but the rears are the wider 225s. You either need the 185F/205R factory sizes, or the 195/50/15F & 225/45/16R wider fit that most folk go for.
HTH
Fronts: 195/50/15
http://www.camskill.co.uk/products.php? ... b0s99p3596
Rears: 225/45/16
http://www.camskill.co.uk/products.php? ... 0s310p6373
I'd trust most of SE over the previous owner of your car.
I'd also ignore the fact it's a 111s since I reckon that pretty much just means the engine is VVC, the interior is different, and the wheels are a different style, compared to say my regular Elise.
Fairly certain the suspension / anything else relating to the handling/tyres is identical no?
Chris
Re: Barum Tyres
Scott
Does Holly actually let you out on your own?
Re: Barum Tyres
Not strictly true - the rear rims on a 111S were half an inch wider.Corranga wrote:
Chris
Re: Barum Tyres
Hahaha sometimes if I am a good boytut wrote:Scott
This tyre stuff really confusses me though, I just thought order same size as the tyres on the car
Re: Barum Tyres
Corranga wrote:I think everyone is pointing you here:Tom wrote:Not quite the right ones. The fronts you have have there are the narrow 185s, but the rears are the wider 225s. You either need the 185F/205R factory sizes, or the 195/50/15F & 225/45/16R wider fit that most folk go for.
HTH
Fronts: 195/50/15
Rears: 225/45/16
Chris
Thanks I will order these at lunch and I hope these will definately fit. I know the wheels are slightly different at the rear. My suspension is different and been lowered quite a bit, noticable when I was on the road run and everyone managed down to the car park apart from me who could get down the hill as it was scraping in the middle. Just want to make sure the tyres will be 100% fit without rubbing arches etc or the car dropping down too much?
