New exhaust recommendations?
Post by Shug » Fri Apr 21, 2006 1:14 pm
Not sure if 'frauds do them, but it's a standard MGF part.
offshorematt
Post by offshorematt » Fri Apr 21, 2006 1:36 pm
Just been thinking, there must have been a good 1 1/2" or 2" of pipe vanished from both ends of the silencer so the fumes were going no where near the tail pipes. Get this, it failed the MOT recently on emissions :shock: Reckon the boy couldn't get a reading and just figured he'd fail it? Didn't really matter - I only booked it in to confirm I needed a steering rack :wink:
Post by robin » Fri Apr 21, 2006 3:54 pm
RICHARDHUMBLE wrote:Dont forget a big hammer and a Hamish for the rusted solid nuts :thumbsup
*cough*
:wink:
andysc
Post by andysc » Fri Apr 21, 2006 4:17 pm
Hey Matt,
here's my 2p worth on taking the old one off, as I've just done it.
Go to halfrauds an buy Loctite Freeze & Release.
Car up on Ramps, remove undertray.
Keep grinder inbox but close to hand.....
starting at the cat intake end, lower bolt.
Spray loctite miracle worker onto bolt threads for 5 seconds. Leave approx 30 secs. Get deep socket & 10" breaker bar and will release easy.
Repeat for all cat intake end.
take off all hangers holding exhaust on. The one at cat exhaust end is a pain but will come with miracle spray making it easier.
the whole exhaust & cat can now be VERY carefully angled down & out. Its atight squeeze but it will come. I had the janspeed sport from the factory, not sure how that compares to yours though.
Once its out use the spray on the remaining bolts. I had to use the hacksaw on only one as the head was corroded round :shock:
The larini has 8mm plate flanges, which I noticed have deformed, I assume through the welding process....... I had to use exhaust gasket sealant with the gaskets to get a seal. Larini have been informed
Sould be getting my non squint one next week :D
Andy
offshorematt
Post by offshorematt » Sat Apr 22, 2006 7:48 pm
Nice one, I'll give the Loctite Spray a shot. Shouldn't have any problem getting the old exhaust out though - its in two pieces already... :?
