New toy
Re: New car at last! :)‏ Suspension?
Post by Mike Scib » Fri Jul 24, 2009 5:40 pm
Andy G wrote:Believe the Wiley Ocelot, otherwise known as the legend that is Steve Williams, also has his own Nitron set-up now, according to Cpt Iddon :thumbsup
Expect to see it on an S2 135R near you soon :mrgreen:
And Cpt Iddon's LSS on a S1 135 soon :mrgreen:
Post by campbell » Fri Jul 24, 2009 10:41 pm
So tell us, what has El Capitane planned to replace his LSS with?! Does it begin with an N...
Post by mckeann » Fri Jul 24, 2009 10:57 pm
campbell wrote:So tell us, what has El Capitane planned to replace his LSS with?! Does it begin with an N...
read the post 2 above yours :wink:
and yes, nitrons. They're sooper dooper stevie spec dampers with mcape/iddon spec spring ratings. you can be sure they handle like a pile of turd :damnfunny
Post by campbell » Fri Jul 24, 2009 11:01 pm
doh
thanks Neil!
sounds very nice
and hard
Post by mckeann » Fri Jul 24, 2009 11:34 pm
They do a road spec and a track spec, but we're calling these mountain spec :thumbsup
Your welcome to a shot of them to see what you think.
Post by Mike Scib » Sat Jul 25, 2009 12:02 am
woody wrote:25/45 brackets.
My car is at 105/115 F/R with plenty of droop travel. If you need a handy regarding them, give me a shout again.
25/45 brackets then mate? Are S2 dampers the same length as S1 :?
Anything else i should be buying for a suspension change over then?
Will give you a shout if you don't mind as i have no idea how to set them up :oops:
Post by campbell » Sat Jul 25, 2009 7:18 am
mckeann wrote:They do a road spec and a track spec, but we're calling these mountain spec :thumbsup
Are they fitted yet?! I will hold you to that. I'll be around the house tonight and most of tomorrow tackling jobs and chores, if you happen by.
Post by tut » Sat Jul 25, 2009 8:47 am
Robin or Neil
As I am sending my Nitrons for a rebuild, what do you reckon is the best path to take? Was only looking at Nitron, then saw that Randy gives the same service, but Scotty said that he sends them off to Nitron, so to have a word with Walshy first.
Would love to go for the full Hoffmans set up but can not afford that, so it will have to be the standard rebuild which is still £280.
ps yo, 7,999.
Post by mckeann » Sat Jul 25, 2009 8:27 pm
Tut, it is very expensive to upgrade normal nitrons to hofman or stevie spec, so your probably best just to rebuild your as is, assuming your springs are ok.#
Campbell, havent got the dampers yet, hopefully sometime this week, and get them fitted by the end of the week (if all goes to plan)
Post by mwmackenzie » Sat Jul 25, 2009 10:22 pm
I have the S2 LSS on mine and bought the mounts from Eliseparts, The S2 LSS are height adjustable but I think they are indeed longer so the brackets move the mounting point higher up if I remember correctly.. mine is at SLS if you want to have a look... i wanted mine lower but the spring seems to come away from the seat when there is no load on it when you lower it too much, I have mine set so the adjustable collar is about half way up the shock to allow a decent amount of travel so they don't bottom out to much and and the springs dont loose tension when the car is lifted or becomes light or airbourne. I think Steve Butts has different brackets to suit different ride heights, not sure though, you'll find him on SELOC. All the best mate
Mark :cheers
Post by ed » Sat Jul 25, 2009 10:37 pm
Make sure the nitrons are clean before you send them tut as when I sent in some with dirt on them they charged me to wash them..... :oops: :roll: :lol:
Post by tut » Sun Jul 26, 2009 9:32 am
Thanks Ed, was just about to send them and they are pretty manky, so will take them out and clean them.
Post by Mike Scib » Sun Aug 02, 2009 10:37 pm
The last few weeks have been 1 step forward 2 steps back with the Elise but seem to be getting there slowly now, hopefully in time for Saturday when we head to Dover!
First up BIG :thumbsup to Dan from SPS for going out has way on a Sunday to fit a new AP clutch kit and release arm with only 24 hours notice!! :thumbsup :thumbsup :thumbsup The release bearing had gone and i had been told they can go at any point so with 3000+ hard miles looming i thought it would be best to get it done and from what Dan was saying it was lucky i did :shock: .
Also serviced the car with the father-in-law so oil and filter change, fuel filter change which looked like it had been on a while as it was seized and the fuel that came out was black!, Plug change, distributor cap and rotor arm replaced and a new brake light switch fitted.
Also managed to fit my Carbotech's XP8's all round, so looking forward to trying them on track :twisted:
To do before Sat, fit my S2 LSS suspension which hopefully i will be picking up tomorrow all going to plan and then try and set up the ride heights followed by a geo on Wednesday. And finally fit 2 wheel bearings :roll:
Mike
roadboy
Post by roadboy » Sun Aug 02, 2009 10:42 pm
Mike Scib wrote:First up BIG :thumbsup to Dan from JPS
Tis SPS Mike. SPS! :thumbsup
Good to catch up again today.
YHPM btw.
Dan
SPS Automotive
Independent Lotus Specialists
Post by Mike Scib » Sun Aug 02, 2009 10:44 pm
Don't know what your taking about :oops: :roll:
