New toy
Re: New car at last! :)‏ Suspension?
Post by Shug » Fri Jul 03, 2009 11:38 am
They got as far as final testing prototypes (Noops was in the test group) before canning them, as they couldn't get the build consistency they wanted. Assuming these are designed differently, or they have another manufacturing option (reds were outsourced build to a Nitron design).
roadboy
Post by roadboy » Fri Jul 03, 2009 7:00 pm
Shug wrote:They got as far as final testing prototypes (Noops was in the test group) before canning them, as they couldn't get the build consistency they wanted.
The issue was actually down to noise and I'm sure it could have been sorted but Guy got a bit pissed off with how some of the Beta testers behaved so decided it wasn't worth the hassle. The Reds were a great product with excellent damping but the noise issue spoilt the party.
Realistically, I would think it will be early next year before the Street Series dampers are ready for general release.
Dan
SPS Automotive
Independent Lotus Specialists
Post by Mike Scib » Sat Jul 04, 2009 12:25 am
Standard Koni Reds now on :shock:
Post by Mike Scib » Tue Jul 07, 2009 11:19 pm
woody wrote:The S2 LSS isn't particuarly road biased in that it has very harsh damping. These Nitrons have 2.25" Dia. Springs unlike the Lotus Bilsteins, so the springs can be swapped out for ones a more appropriate rate. I'd doubt you'll be able to go as high a rate as normal Nitrons, but the damping should still be more suited to the car.
Reply from Nitron;
"Hello Mike,
The Nitron Street Series shocks will be released by October.
If you do track days we would recommend to have NTR single adjustable shocks.
The Street Series shocks will come with one spring rate. The spring rates for Elise S1 will be 275lbs on front and 350lbs on rear.
Best regards,
Dora"
Post by woody » Tue Jul 07, 2009 11:25 pm
Reply from Nitron;
"Hello Mike,
Best regards,
Dora"
Good to know,thanks. Still stiffer than standard or LSS bilsteins then.
Post by Mike Scib » Tue Jul 07, 2009 11:30 pm
Any idea what spring rates are on the single adjustment ones?
roadboy
Post by roadboy » Tue Jul 07, 2009 11:35 pm
scib4 wrote:Any idea what spring rates are on the single adjustment ones?
Do you mean the Nitron NTR one ways? If so, they come standard with 325/400 f/r but most people found them better with 400/500 or 450/550 springs. To be honest there's no way I would spend money on Nitron NTRs with standard valving. If you're going to spend that sort of money then it makes much more sense to get them from Hoffmans with their valving as it is a massive massive improvement over the standard valving.
Dan
SPS Automotive
Post by Mike Scib » Thu Jul 23, 2009 5:47 pm
Mike Scib wrote:Standard Koni Reds now on :shock:
Thought i would up date this thread. Since fitting the Koni Reds i managed to sneak onto the LOT day on Monday for the last 2 dry hours. Got to say really not as bad as i was expecting and i thought they were going to be shocking from what i have read! Just goes to show how bad the S2000 was on track :damnfunny
Took Mckeanns advice with a bit of trail braking going into the corners, Awesome!! especially when you get it right with the car just balanced on the edge of oversteer :D The only time the suspension got upset was with quick direction changes and taking to much kerb. And god knows what the geo is set at at the moment :roll:
Can't wait to get my S2 LSS on now :mrgreen: BTW what brackets heights should i be looking to use? 15/35, 25/45 or 15/45 :?
Post by woody » Thu Jul 23, 2009 6:15 pm
25/45 brackets.
My car is at 105/115 F/R with plenty of droop travel. If you need a handy regarding them, give me a shout again.
Post by Victor Meldrew » Thu Jul 23, 2009 7:58 pm
Reply from Nitron;
"Hello Mike,
Best regards,
Dora"
That is soft as butter... and not a real reflection on relative ride comfort.
admittedly I'm running the Hofmann's set up with 550lb's on front and 750lb's on the rear, but they have the lighter helper springs on both ends. The combination with these helper springs (which are not quite fully coil bound at rest) is excellent on road. You get a little compliance on small bumps and ripples and because the damping balance between bump and rebound has been adjusted by Hofmann's to suit the Elise specifically the ride is excellent.
Standard Lotus Nitrons are specced by length, so if you have a land rover with the same length shock it will have the same bump rebound ratio... i.e. not optimised for kerb hopping light weights like the Elise.
There is in my opinion no suspension set up better for the Elise. As far as cost goes, yes there expensive. Maybe Hofmann's will do their own version of the new street shock. Or possibly as Nitron are saying that these new shocks are specific to the Elise then maybe they have changed the balance on these new ones.
Your welcome to come out for a run in mine to see haw the car feels on the Hofmann's set up.
I run at 95mm front and 105mm rear with an uprated 1" hofmans anti roll bar as well. (now that's a piece of kit......)
Post by woody » Thu Jul 23, 2009 8:08 pm
Btw Mike, check your LSS adjustment rings are free to turn before fitting them to the car; they're bad for seizing. One of mine took 600+ lbft and didn't budge (It's an on-going saga :roll: ) but the sleeve and cateram rings that can be machined to suit are available from Bilstein.
craigs135s
Post by craigs135s » Thu Jul 23, 2009 8:52 pm
Mike your car looks great.. So tempted to buy my old one back :P
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
Post by campbell » Thu Jul 23, 2009 10:51 pm
The Konis were never so bad on general handling, it was just their short lifespan and early clonkiness that let them down...I did several KH days on mine and had no regrets. The main thing is you got out for a shottie at all, so well done there :-)
Looks like I may be babysitting my brother's Honda S2000 while he is on hols, so I think I shall have to be careful if I take it out to, er, "free the brakes off a little" ;-)
Noops
Post by Noops » Thu Jul 23, 2009 11:10 pm
My old RR are still running :thumbsup :thumbsup :thumbsup , Victors and my suspension run more or less the same in handling.......although mine are somewhat noisy,direct ,and works.....and Victor's seems to be more direct ,works'
silent ...however worked in a Oh I've paid .......way , I'm not taking away what Victors spent on Suspension....my problem is what I spend replacing my RR's and spending a grand extra for the same suspension..
However what do I know............. :wink:
Noops
Post by Andy G » Fri Jul 24, 2009 10:08 am
Believe the Wiley Ocelot, otherwise known as the legend that is Steve Williams, also has his own Nitron set-up now, according to Cpt Iddon :thumbsup
Expect to see it on an S2 135R near you soon :mrgreen:
