Best cleaner for removing splatted flies?
Only had the car back a few days an it's covered! Didn't mind using an old rough cloth to remove them w the old clam but new one's too shiney for that.
S1 50th Ann.
- alicrozier
Baby wipes if you're out and about.
Washing at home I use a 'bug and tar remover' not sure which one but it fair takes off the bugs and has a bit of wax content.
They seem to come off the Defendall easier than the paint...
- tuscan_thunder
I do a bit of valeting in my spare time (shameless plug - PM me if you need your car done - mates rates for SE guys) and for bug removal I do this:
power wash (with pressure turned down on paintwork, up on glass)
wash it with car shampoo (using a wash mitt and 2 bucket method) my favoured detergent at the moment is Auto Gype bodywork shampoo conditioner
really soak the flies with detergent
wash off with hose
if they're still there, I use a microfibre cloth with a drop of cleaner wax to lift them off or clay bar them using quik detailer. (if they're on glass, then I clay bar)
If the paint is treated well with polish and a wax layer, the flies should slide off with powerwashing and maybe a light pass over with a wash mitt.
wash off with hose
Re: Best cleaner for removing splatted flies?
Angle Grinder..... the man's wayScottd wrote:Only had the car back a few days an it's covered! Didn't mind using an old rough cloth to remove them w the old clam but new one's too shiney for that.
- bertieduff
i take it thats an old photo rather than a new scrapeShug wrote:Angle Grinder..... the man's wayScottd wrote:Only had the car back a few days an it's covered! Didn't mind using an old rough cloth to remove them w the old clam but new one's too shiney for that.
1995 Volvo 940SE Estate
Och aye - that was the car just after the Cadwell shunt. Rubber marks t-cut out... Gaffer tape is still there thoughTom wrote:i take it thats an old photo rather than a new scrapeShug wrote:Angle Grinder..... the man's wayScottd wrote:Only had the car back a few days an it's covered! Didn't mind using an old rough cloth to remove them w the old clam but new one's too shiney for that.
. tax disc looks old
Did you damage suspension/radiator??Shug wrote: Och aye - that was the car just after the Cadwell shunt. Rubber marks t-cut out... Gaffer tape is still there though
Nooo - just cosmetic. Was at walking pace and 3/4 on. The windscreen got cracked as the clam popped off it's bolts and the corner banged the screen. Apart from that, no other damage. Didn't even knock the geo.Tom wrote:Did you damage suspension/radiator??Shug wrote: Och aye - that was the car just after the Cadwell shunt. Rubber marks t-cut out... Gaffer tape is still there though
