Paint removal (dulux !)
Take good care of her
IanD
Post by IanD » Thu Oct 07, 2010 9:22 pm
Even although I moved the cars away from the house I have a lots of tiny dulux weathershield paint spots on both the car bonnets after doing some house exterior wood painting. Paint is a non water soluble one.
What is the best way to remove the spots ?
White Porsche man
2010 Boxster Spyder
1993 968 ClubSport - see it @https://youtu.be/8PnI0VE1B54 SOLD
Re: Paint removal (dulux !)
Post by j2 lot » Thu Oct 07, 2010 9:30 pm
Don't know - but if you find a solution let me know we have a Corsa that has had white paint specs on blue bodywork for a couple of years and still can't shift them :evil: i
Post by campbell » Thu Oct 07, 2010 9:44 pm
Start with Meths.
Resort to White Spirit or Benzene only in desperation *.
I also have a tin of weird spirits from one of our resident bodywork experts, it's called Teroson Cleaner & Diluent, smells mental and has traces of benzene so presumably pretty nasty stuff :shock: Used it to good effect to remove silicone sealant and tar from the Elise bodywork, with zero ill effects.
Prob a trade-only product though.
Campbell
* - joke. But I do think Meths is worth a shot, it's present in many screenwashes and does not attack vehicle paint AFAIK. No warrant express or implied ;-)
Post by mac » Fri Oct 08, 2010 9:08 am
Once it's dried I don't think you'll have much luck in getting it removed with solvents.
Given that it's technically sitting on the surface of the car's paint work I would use a mild rubbing compound such as T-Cut, if this doesn't work then it will be a job for a profesional and most likely a machine polish.
2p
allyrennie
Post by allyrennie » Fri Oct 08, 2010 6:24 pm
Give it a good wash then get yourself a clay bar kit from halfords, you will find that takes a lot of it off.
A Product like tardis from Autosmart may also help, really works when breaking down things like paint....
t-cut is quite harsh on modern paints, only use it if your going to follow up with a good sealant etc
If I can help you at all let me know!
Ally
tuscan_thunder
Post by tuscan_thunder » Mon Oct 11, 2010 4:51 pm
As per Ally's advice - Tardis is the best option. http://www.polishedbliss.co.uk/acatalog ... ardis.html
Then move to clay - an aggressive one like the Gloss It aggressive would be ideal. http://www.polishedbliss.co.uk/acatalog ... y-bar.html This, worked carefully and for long enough, should remove it. After that it's machine polishing time.
Don't, please don't use T-Cut. It won't break down (eg, the abrasives will just stay the same, even after being worked) it will remove lots of paint and it will micromar the finish, requiring a follow-up polish.
If you need any other help with products (I'll leave Ally to do the hands-on stuff - he's a good bit closer to you than we are!), let me know via http://www.polishedbliss.co.uk
(Ally - your website is down!)
Mair throttle, less brake
Justin
Post by Justin » Mon Oct 11, 2010 4:58 pm
As above, Clay bar, or Tardis should take it off
g1zmo26
Post by g1zmo26 » Mon Oct 11, 2010 9:43 pm
campbell wrote:Start with Meths.
Campbell
Expert not been called that in a while!! :)
Post by campbell » Mon Oct 11, 2010 11:20 pm
Hello buddy, how's tricks!
Still using that Teroson stuff to great effect occasionally. Thanks again :-)
IanD
Post by IanD » Sun Oct 17, 2010 12:09 am
Cheers thanks for advice and wisdom.
Bought a clay bar last week and gave it a go today on some trial patches and it works slowly taking off almost all the spots. Will try some tardis for the more stubborn bigger spots.
Been too busy over the last week enjoying myself on holiday in Castle Douglas and having some fun runs in the Elise to use the clay bar before today.
Will probably give you guys at polished bliss a ring next week and buy some polish as have been looking at your website over the past month.
White Porsche man
2010 Boxster Spyder
tuscan_thunder
Post by tuscan_thunder » Tue Oct 19, 2010 10:49 am
IanD wrote:Cheers thanks for advice and wisdom.
Feel free - it'll likely be me you get on the phone - whether that's a good thing or a bad thing, I'm not sure!
