Mildew stain removal
Take good care of her
fudnie
Post by fudnie » Sat Feb 14, 2009 3:18 pm
Does any body know the best way to remove white mildew stains from a soft top?
S2 111S blue with silver stripes - The Good
56 Astra in black - The Bad
Rover 45 in maroon - The Ugly
Re: Mildew stain removal
Post by tut » Sat Feb 14, 2009 3:31 pm
Yep, keep Scotty away from it when he gets excited......
Post by campbell » Sat Feb 14, 2009 5:30 pm
Inside or outside?
Inside, just wade straight in with Dettol Anti-bacterial spray, worked in with sponge and warm water. Leave to absorb for a wee while then rinse well (hang the roof over the washing line and hose it, I find works best!).
Outside, better to stay away from strong chemicals, in which case have good go with pure soap cleaner (like you get for washing goretex garments) or the refurb kit you can get from Eliseparts (and others) - Renovo. Fit the roof, wet it, apply the cleaner in solution from a bucket using a nylon-bristled brush (I have a wee circular scrubbing brush, bit like a shaving brush, which works great). Once worked in, again leave to soak a while then hose off well. Get some waterproofer on right away though. Nikwax spray on is good, 2 coats might be needed. Or again, the Renovo kit has a proofer included. This will reduce the likelihood of further mildew, as the roof canvas then holds less water and has less to let the naughty wee spores grow in.
HTH
Campbell
fudnie
Post by fudnie » Sun Feb 15, 2009 7:08 pm
cheers for that
its actually on the inside of my mx5s roof. not sure if i can take if off easily but I have bought a "mildew stain remover" stuff, will let you know how i get on.
Craig
Post by campbell » Sun Feb 15, 2009 7:11 pm
Ah right.
You can probably still spray the Dettol up inside the roof while fitted...just watch your eyes!
Or make up a solution of the stuff in a bucket/basin and sponge it in.
Worst case, the roof fabric *will* come away, although you may need a workshop manual. Or can the roof assembly be detached to enable use of a hardtop instead?
Best of luck.
stu331
Post by stu331 » Sun Feb 15, 2009 9:33 pm
If you mean from this: -
To this: -
You'll need some Soda Crystals (from Tesco 60p per pack), add 3oz to 460ml of water and 60ml of Megs APC.......you would probably get away without the APC if you don't have any.
Just spray on, brush then rinse if it's as bad as the one I did shown in the pics (which I doubt) you will need a couple of applications.
331
Post by DDtB » Thu Feb 19, 2009 12:42 am
hey, you're car is the same colour as Dom's golf!
Nice!
Post by Dominic » Thu Feb 19, 2009 1:03 pm
These are your's Dave;
:finger
Well we all knew Dave would have something to post on 'stain removal'... was not expecting a pic of my car though! :shock:
stu331
Post by stu331 » Fri Feb 20, 2009 1:44 pm
You would be advised to apply a protectant after cleaning this will guard against grime, dirt, milldew etc and water will bead like crazy and run straight off the roof, the white "specs" in the after picture is the protectant that had just been applied when dry it is invisable........303 aerospace is what I used.
Also, if it's cold switch the heater on re-circ and it will dry within minutes which allow for a second application.
331
